What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.20.2007, 11:53 PM
Please state whether you think I should take this project to new heights:
Exhibit A: Ofna 1/8 Ultra GTP ARR Chassis
Exhibit B: There is no exhibit B.
I'm toying with the idea of buying one of these and putting two (what did he just say?) of the 90mm EDF units on it. Each with it's own Feigao 8XL since I really think the fan is capable of much more that a 9XL can attest to. The BIG plus here is the pre-installed brake system. Two MM's for control (possible thrust variance in corners?) and, since the fan blade weighs nothing, I can probably use the same MaxAmps Batteries (4s 4000mAh) in parallel for 160A total continous output. Although I really dont think I'll need anywhere near that amount of power.
DO IT!!!
