DrKnow65
DrKnow65's Avatar
10.21.2007, 03:07 PM
GriffenRU, thanks for the reply
1) bummer, guess I'll be removing the ESC when I change the settings
2) nothing wrong with the part you listed, just thoughtif I was changing the case size I could go to bigger caps (got the impression this was somthing you wanted to do but decided to keep the original size (different spec's) caps to fit the case. I was hoping bigger fets would help with efficiency
3) an additional 6mm too much? I'd like to be able to heat sink both sides... How do you do it on your mod with 2 boards?
4) cool
5) will draw something to post asap, I don't think my "idea book" is quality enough to help someone else see what I'm thinking...
