10.21.2007, 03:08 PM
Cant say much about the shocks, since Im using MRS4s on my Gmaxx. That is a very solidly built truck, but I would say go to plastic bumper mounts- good idea to have some give & a weak point, saves transfering the impact of a crash to the more vital areas. As for the cvd issue, I would email Mike and get some modified out put shafts for your diffs; these allow the use of 3.3spec slider shafts (you will need the 3.3knuckles & turnbuckles too). Other than that its a damn near perfect setup- is that a green Neu? Looks green in the photos. I would however loose the 2speed- not needed unless you do lots of lowspeed crawling aswell as high speed driving.
