GriffinRU
10.21.2007, 04:11 PM
Originally Posted by DrKnow65 View Post
GriffenRU, thanks for the reply
1) bummer, guess I'll be removing the ESC when I change the settings
2) nothing wrong with the part you listed, just thoughtif I was changing the case size I could go to bigger caps (got the impression this was somthing you wanted to do but decided to keep the original size (different spec's) caps to fit the case. I was hoping bigger fets would help with efficiency
3) an additional 6mm too much? I'd like to be able to heat sink both sides... How do you do it on your mod with 2 boards?
4) cool
5) will draw something to post asap, I don't think my "idea book" is quality enough to help someone else see what I'm thinking...
3. 6-10mm would be Ok, it wasn't clear how far you want to move brains board from FET's. :)
I have the same brass plate as with mod 1, but to improve heatsinking, I do polish FET's and brass plate on sand paper. Do not try too hard on FET's...
