MetalMan
MetalMan's Avatar
08.04.2005, 03:15 PM
The aluminum/steel diff isn't necessary. You just need an aluminum idler. Switching to using these steel balls instead of diff pegs will make the slipper work better:
http://www2.towerhobbies.com/cgi-bin...?&I=LX2760&P=7
Also, upgrading to RPM bearing carriers with bearings will be a very good idea.
