MetalMan
MetalMan's Avatar
10.22.2007, 03:18 PM
Originally Posted by dabid View Post
Travis, why? This one seems to have stupid torque even over geared, but is small enough that it's not hitting the Stealth tranny. Besides, doesn't that one have a 5mm shaft? It wasn't too hard to make the 4mm to 1/8" conversion, but 5mm to 1/8" would be a bit harder.....and I still think it's too big.
You think the torque of your motor is stupid .
I have access to a machine shop at UCI (University of California, Irvine), where I go to school. Outrunners feature removable shafts, so I simply took the shaft out of the motor, and turned it from 5mm to 1/8". When it still had the 5mm shaft, I was running mod1 gears. Now with the 1/8" shaft, I occasionally have a problem with stripping 32p gears, and would strip out 48p spurs all the time.
