BlackedOutREVO
10.22.2007, 04:59 PM
Well, I think I want the Emaxx, the .5 is sooo cool, but I just dont think it will do what I want it to do in terms of off roading, I need ground clearance, and the Maxx has that, and I just sorta want a big-ish truck again
So, looks like the first MMM stuff out will be the NEU 1515 1Y 2200KV, so it is a 4s motor, and its a 1515, which isnt a issue as I might add alu and all, so im more then fine with the bigger motor, and in its bigger, so it should have more torque, which I hope will make it run cooler further running it on 4s in the Maxx
So, the list (so far) is
New E-Maxx
MMM combo with the wanta-be NEU 1515 1Y
2 TrakPower gold packs
And then I have some 40s series road rage that arent even glued to rims yet (meaning there new) on velocity 6 rims........
And the wants
New off road tires (dont know which ones)
The red tubes
spektrum rx (already have the radio and all that)
new shocks (UE's)
When made, alu bulks (the flm wont work because of the new bearing size) Same with all others
And thats abut all I can think of
