10.23.2007, 03:19 PM
If for some other reason you need the end cap off the motor, just remove the screws from the REAR endbell and tap the shaft onto a solid surface. This will push the endbell off and pop the rotor out too. Don't get too carried away cuase you do not want to knock the magnet off the shaft!
