DickyT
10.23.2007, 04:41 PM
Originally Posted by chilledoutuk View Post
if you want to solder the motor directly to the esc why not just remover the bulltet connectors and solder directly to the esc board.
I would however recommend that you just shorten the wires as its not easy soldering the tabs on the mamba max unless you have a very powerful soldering iron.
The wires are not long enough to get from the motor to the ESC so I was going to replace all 3 with custom length wires. I have a weller soldering station with several temp irons and a big ole' bottle of flux so that is not concern.
Maybe I'll just leave it alone, I am not trying to correct an issue, just to increase efficiency.
Thanks for your replays.
