Aragon
10.25.2007, 02:49 PM
@Aragon: I see what you are saying. However, a coil can deliver more voltage than what was put into it if the magnetic field is allowed to collapse faster than it was built up. Take any coil, apply a 9v battery on it, and then remove the battery. Depending on the coil rating (in milli-henries), a voltage MUCH MUCH higher can be generated. This is how the cow fences I've seen operate. Applied to R/C; depending on how fast you brake, the field can collapse faster than it was built up and can generate higher voltages than the battery.
Do you have more info on this? Or a better explanation? :)
