DrKnow65
DrKnow65's Avatar
10.26.2007, 01:08 AM
hey guys, anyone know of a way to fix a fet that was not soldered down properly?
if the picture stops working like most of mine have, you can go to
http://imageevent.com/drknow65/rccarstuff
and look at photo #19 (be sure to click "original" on the size option at the bottom) or view #20 to see just the one fet...
I tried heating it with a soldering gun and then soldering with a 30watt iron to no avail. The minor damage that was done to one corner was done when removing the heat sink, it was already lifted which is why the sink was not attached properly to begin with.
Any ideas?
here is a link to the fet info itself if this helps or if you're just curious...
http://www.ortodoxism.ro/datasheets/...3S_Rev1.11.pdf
