david lamontagn
10.26.2007, 09:49 PM
Hey jhautz, which grade of diff fluid you use in your front and rear V1 diff?? I've mine in hand now and the only thing i have to do before closing it is put fluid in it. I was thinking about 7000 front and 5000 rear. What do you think of that???
Other thing, with which type of grease did you lube your pinion/ring gear??
Thank you very much
David
