10.27.2007, 02:47 PM
I have an all al pede and have had no issues. Make sure that you keep the signal wires from the esc and servo away from the motor leads. You can try braiding the motor leads, as twisted wires tend to emit less noise. Make sure that your antenna is as far away from the esc as possible. I have my signal wires tied to the chassis along the side with zipties and have not had any issues. A cap that plugs into the receiver is a good idea as it will smooth out the power from the esc. Otherwise you may have a bad esc, since you have checked the receiver.
