10.28.2007, 09:43 AM
Hmm, good question. All the aftermarket ones I have seen use the same template as the stock item, as it were, so there is no extra adjustability in that department. Its either dremel time, or you could make you own mount from a small sheet of 1/4" aluminum- like this sort of:
Another one of the Candyman's masterpieces....
