othello
HV basher
10.29.2007, 09:10 PM
Very "cool" HV setup. Thanx for sharing all your data. Wow ... i never managed to discharge my 10s A123 pack in under 10 minutes. Grass is definitively the best torture you can put your setup through. 1700 Watt is the maximum i saw with my Buggy too. What does your Revo wheigh fully loaded?
Reason i ask is: i just finished my 3rd conversion and moved all my HV stuff (Jazz 55+Neu1512/2Y+10s1p A123) from my buggy in a truggy which now wheighs 10.8lbs (4,9Kg). I think your data should be pretty close to what i will see (after fitting a hardened steel pinion) since i geared her for 40mph.
I hope you don't mind when i post some pics and data here too. I maidened her today on concrete but was short of a hardened steel pinion so i took it very easy with a non hardened one which survived only for 4 minutes: pic of my setup, Eagletree graph, video with my broken video cam
