rchippie
rchippie's Avatar
10.31.2007, 10:53 PM
Looks just like my 40x40mm 5v fans, and you would need two really, though the RCM heat sink/clamp would be better with a couple of those or one 50mm fan.
I agree with you on mikes mount being better, & would like to use it. But his heatsink does not fit my 1950 the same way it fits my 9XL for some reason. It fits my 9XL perfectly with no gaps, but on my 1950 i cant get his clamp to sit all the way down, thous it leaves a small gap between the top of the motor & the clamp. I think i know what the problem is. I measured my 9xl it is 35.8mm & the 1950 is 36.6mm in diamiter just enough so his clamp wont fit.
REAL MEN RUN BRUSHLESS
