11.01.2007, 12:22 AM
Based on personal experience, Ii you are going to run ANY brushless motor on a mm (except a tiny one!) Griffinru's mods will make a huge improvement in startup and overall heat management. I ran a 7xl on a stock mm and a modded mm and the stock one had to have a fan to work and even then it got hotter than the modded mm did with out a fan. I ran the modded mm thru 2 packs back to back (at least 40mins) and it did not get over 140f. Well worth the $50 or so he charges. I currently have 2 mm that I sent him to mod and will run them both on 7xl motors in two new vehicles that I am converting.
