11.02.2007, 12:41 AM
Hey John, you need to switch over to the jato .8 mod spurs. I am assuming that you have the xl5 slipper , which will bolt right up to the jato spur. The 58t gear works well and should give you some extra room. If not a mgt 46 tooth mod1 spur can be made to work and will clear most outdrives. Do you have an 1/8 or 5mm shaft? The emaxx 32p pinions will work with the jato .8 mod spurs if using 1/8" shaft, or buy 5mm pinions from mike here at rcm.
