tashpop
11.02.2007, 07:42 AM
it never crossed my mind to use the break hardware/spot as a mounting location. its looking good. i'll have mine mounted today. wife wouldn't let me finish it last night after work. everything is done, but i need to open the hole a little where the motor shaft goes through. last test fit, my pinion set screw was contacting the spur a little and i couldn't set it back further because the mount hole wasn't big enough for it to pass through.
mamba esc's have 3.5mm plugs right? my feigao didn't come with any plugs so i have to hit the lhs on the way home tonight.
