A4DTM
11.02.2007, 08:29 PM
well I got the cases.. but ugh.. not the best company? or someone just being lazy? 2 silver end plates, and only 1 black end plate..
the bigger problem, is they're 1/8" too short for my 5Ah packs. my 4Ah pack fits, but just BARELY.. it stays in from the friction on the ends.. I'm planning on returning one of the cases for a refund, and keeping the other one for my MT2. I figure I'll most likely get smaller packs in the future for the MT2.. if I ever get new packs for it..
but, with foam on the bottom sides and top.. do you think the pack will be ok, say if the truck dropped 30 feet onto it's nose? it just doesn't seem like a good idea incase of a front/rear impact. but the heatshrink and wires and plastic and tape will all reduce some of the impact. anyways, here's the pics i just took.
w/ the 5s1p 4Ah pack:
here you can see the 5Ah pack just barely doesn't fit :(
oooh i just had an idea... think if I screw four holes through the side of the case, and zip tie the quark to it, it'll work as a big enough heat sink? :)
