I believe i pulled off a first, I broke an RC-Monster diff pinion
crazyjr
crazyjr's Avatar
I believe i pulled off a first, I broke an RC-Monster diff pinion - 11.03.2007, 09:44 PM
I broke the pinion of a RC-Monster diff conversion, I had run at the track for a bit and had some trouble with my MGM, I swapped the MGM for my quark 125 and run in the yard for a bitafter a few small jumps and a few speed runs to make sure the esc was ok, i lost the rear wheels power (thought i had a setscrew loose again). I am going to see if mike can get me one without a conversion. I will post pics later tonight or tomorrow, i just thought you guys might want to know. I think i figured it out though, the pinion is drilled for weight and when mike machined it down it went too thin, A sharp jar might break it. I got to say, the Neu 1515/2.5d (1700kv) is impressive on power
