Originally Posted by squeeforever
My only suggestion would be to use a center diff for something that Mike already has a mount for. One of them can use the mechanical brakes (XT8 mount I think), but more are to come soon, so that might be a good option....
The only problem is that all these require side mounted motors. My motor will be mounted above, on the centerline of the chassis. Therefore, I will be using the "stock" center diff mounts, and creating a totally auxiliary motor mount that allows for the driveshaft to go through it, so the motor can mount above the rear dogbone.
