Re: Maxx Transmission problems...
C.H.U.D.
Re: Maxx Transmission problems... - 08.07.2005, 05:44 PM
Originally posted by Nick
When I put on throttle it makes a high pitch noise, like the teeth in the gears (not the pinion/spur) are not touching properly.
Perhaps you have the spur and pinion mesh too tight. I find when I really crank the spur into the pinion and lock it down the noise level increases significantly. Backing it off a mm usually lessens the noise...and probably makes for better gear life.
Are you seeing incorrect wear on any of your gears (spur, pinion, idler, etc.)?
