Eccentric
11.04.2007, 02:56 PM
+1. tHE HOLE IN THE CENTER IS THE WEAK SPOT ON THIS PINION
Did ou use the 2 speed trany or you lock it in second gear?
Now I don't have a Monster diff so I don't know what the pinion looks like. Torsional strength is highest in the outer radius the metal in the center does little other then add weight. I'll have to see pictures.
