Matthew_Armeni
Matthew_Armeni's Avatar
11.05.2007, 09:06 PM
Originally Posted by electric View Post
hey Matthew_Armeni
what type of battery is that and where did you get it like to know? love the conversion might use it on my revo still looking around for conversions. also would an hv maxx motor fit, don't know might be to long.
That is a TrueRC 4S1P 5000mah battery, you can go to Truerc.com and check out the packs, he offers many different setups. I mostly went with them because they were such a good value and I heard good things about them here.
If you're reffering to the Novak HV motors then no, they will not fit the Tekno conversion. The Elektri-clutch only works with motors that have a 5mm shaft, such as Neu, Fiego/Nemesis/Wanderer. The Novak has a 3.something shaft. If, however, it did have a bigger dia shaft, it would fit (you were thinking it might be too long, it wouldn't, I have a very long motor on mine plus the RC-Monster heatsink and it still fits).
  Send a message via AIM to Matthew_Armeni
