espeefan
11.06.2007, 03:22 AM
Thanks, but it's got a long way to go! It started as a bare chassis, but little by little I was able to buy more parts and add them. That is why you might spot a few changes in the photos. The front suspension was swapped to more realistic springs, to match the rear, and the rear axles were relocated further back then Wedico intended, to make more room for the lift axle.
Here are a couple shots of the axles themselves. The plastic arms are the levers for the locking differentials.
And here is a photo of the aftermarket rear suspension springs designed by another company for the Wedico line, that I bought.
Installed -
An underside photo of the trans and front axle....
Finally, mock-up of the cab clearance lights. I love those trucks with lights everywhere. The more the better. That is what I hope to model.
