11.07.2007, 02:40 AM
So does voltage directly effect motor efficiency? Ive seen people calculate power output by multiplying the motor efficiency by the watts drawn from the battery. Then its assumed that the extra 10-25% is turned into heat. If less amps also means less heat, is that any different from using a better motor?
