11.07.2007, 01:50 PM
to have an airplane esc run succesfully, you need mechanical brakes (this can be don trough a Y cable, to simple devide the throttle channel to the brake servo and the speedo)
and like Brian says; most are made for stick transmitters;
the problem is that normally 0rpm on an airplane is -50% of the throttle possition of a pistol grip. The pistix changes this.
