11.07.2007, 09:54 PM
Yeah, that sounds ok. Unfortunately, the Quark only allows 3v cutoff max, and I like something more like 3.1-3.2v/cell. How long are you waiting after running the pack before you get those voltage readings? The pack voltage should drift back up to ~3.4v+ after sitting unloaded for a while. If not, maybe you're pushing the batts a little too much either by too-tall gearing or using packs that really aren't up to the task...
