11.08.2007, 09:50 PM
I would rig up some skid plates for the top of your shock towers, because I can tell you right now, they won't last a pack's worth of charge. Unless you set your slipper loose, that thing is going to wheelie so fast you won't believe it. I have experience with that same setup, except you are running 2.5v hotter than I was.
I had been intending to make some metal "C" shaped clips to cover the tops of my shock towers so I'd stop wearing them away. Never got around to it though. Nice job on the placement of the cells, good idea to use the size of the body to carry them.
Make sure to take a video of the 1st run, we want to see it while it's in one piece! :)
Sleeb
