Mailman
11.10.2007, 09:40 PM
Caution on new mugen mount - A few issues with the mount at the moment on my MBX5T....
1) The lower mount screw holes weren't long enough - Easily enough to recitify with cutting down the screws
2) The holes that the servo mount slots into weren't quite big enough - Easy fixe by enlarging the holes by running a 4.5mm drill bit in for a minute
3) The motor mount adjustment isn't wide enough - The truggy has a 62t spur - I can't get any pinion on... The mount need to be much wider. - Stumped!
I've attached some pics below:
http://s168.photobucket.com/albums/u180/Arct1k/104.jpg
http://i168.photobucket.com/albums/u180/Arct1k/103.jpg
http://i168.photobucket.com/albums/u180/Arct1k/102.jpg
http://i168.photobucket.com/albums/u180/Arct1k/101.jpg
Cheers
Your spur gear problem is because you have the truggy conversion - not the actual MBX5T. They come with a 46T spur.
