Thread: HV questions
HV questions
HV questions - 11.11.2007, 02:33 AM
Ok, to all of the members here with some HV experience, I have some equipment and lipos here and am thinking of doing an 8s setup in my ultra gtp on road car. I have an aveox 36/24/3 1300kv motor, about the same size as a feigao l can. Esc would be a kontronik 40/10/24. And for lipos I have 2 7200 4s 12c lipos. So I would be right at the esc limit (32v) on 8s. Hopefully the batteries (84amp constant)can keep up with this setup. I would gear for 40mph. Info from Briang's calc are below. Watch think?
Differential Ratio: 3.1428
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 14
Total Voltage: 29.6
Motor KV: 1300
Tire Diameter (inches): 4
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.64 : 1
Total Ratio: 11.44877 : 1
Tire Circumference (inches): 12.57 inches (319.19mm)
Total Motor Speed: 38480 RPM
Vehicle Speed: 40 MPH (64.25km/h)
Effective Speed Rate: 1.35mph/V (2.17kmh/V)
Effective KV Value: 1300
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
