11.11.2007, 06:48 PM
At least if the heatsinks fall off by themselves, there's no risk of damaging the fets by prising them off.... :/
Anyway, I had another crazy thought the other night: since it is simple enough to synchronise two motors of the same type & connect them to on esc, do you think it could be done with two HvMaxx motors and the HvMaxx esc? Im thinking if you just wire up one motor to the esc with the 3 main power wires & sensor wires, then wire the 2nd motor to the 1st (in sync), could the esc handle it with a few simple mods? I've seen how you (GriffinRU) beefed up the pcb traces with copper wire & extra solder to increase amp handling, so do you think it the could handle the amp draw of two 6.5 motors (since they are less demanding of the esc than the 4.5s), or would better fets be required than those fitted as standard?.... just another crazy idea, since twin HvMaxxes would be as good as the Twin VXL setup almost, but having to use two escs, two motors and 28 sub-c cells sounds a bit mad, and 2x 4s is abit expensive for my pocket....
