11.11.2007, 07:10 PM
@serum
>In the first vid, your batteries gave you a 29V@ 35A load, while the 2nd one >gave you a 27V@35A load. Are this different batteries?
I have 2 10s battery packs. Both battery packs come from different Dewalt packs but were built the same way. When driving i always notice that my second battery pack gives a bit more top speed. So it must hold voltage a little bit better than my first pack. But to be honest i never compared my eagletree graphs with this in mind.
Both videos were shot on the same day. The first posted video was actually shot after the second posted video. So on the first video i must have used my second battery pack which at this point must have been better warmed up since we made some very short breaks while we shot at different spots. This part of the video was shot when the battery pack was about half empty. So heat might have played a role also.
Another possible answer might be video capturing itself which i did with 25 frames per second. I don't know how often the voltage gauge is refreshed from the eagletree software (let's suppose at least as often as the LCDs refresh rate which is at 50hz) ... so while capturing i might miss some frames where the needle of the gauge is already at a different point. So this also can explain the voltage difference at the same amperage.
>About these A123 cells; i just read a guy here in Holland is charging his >13S2P pack at 1000watts.. How nice..
Those cells can take a huge abuse even when charged at higher speed then 10A. I myself first used a laboratory power supply which is able to provide 720 Watt (36V and 20A). But i never used it up to its full potential. After 15 charges it broke down on me and since then i use the Hyperion 1210i which is able to recharge one of my packs in 30 minutes at 4-5A.
Since my truggy uses around 400 Watt average i would need a charger which is able to provide 400 Watt to recharge my 2nd battery pack while driving. This way i could drive all day long without a stop. But this is not my usual driving profile.
My second battery pack has a cell which only provides 2000mAh instead of 2300mAh. So it sometimes happens that i overdischarge this cell and 2 or 3 times i already measured her at 0,9V. While recharging at 5A she balances herself and at the end of the charging process she is within 0,01V when compared to the other cells. I never could have done that with a lipo cell. That is one reason i will stay with those heavier A123 cells. They are simply fool proof.
