squeeforever
squeeforever's Avatar
11.12.2007, 10:46 PM
Originally Posted by IBJAMMIN View Post
That's a perty good looking set up to convert the 2 speed is going to be a problem finding a pinion? I like the aluminum suspension I would convert the truck over the buggy more room under the body to play with. The Mamba ESC should be fine if your worried then go with the Quark 33a ESC a MM is not needed and would be a waste of money in a 1/16th scale truck IMO. :)
Looked like it has a two speed after the CB instead of on it like most, so it shouldn't be a problem.
