Originally Posted by ClodMaxx
funny. tower's description lists 'Four Mounging Holes'. what's a mounging hole? is that what helps the truck handle better lutach?
waaaaaay too many funny definitions are bubbling in my head. i'll keep 'em there and spare you guys from my lame humor.
If you own a 1/8 scale truggy or buggy you will know the the MOD1 51T spur has Four mounting holes that attachs to the diff casing. It will not allow the front wheel to unload and cause the vehicle to understeer. It will send power to the front and rear equally. The solid center also helps when you get to a corner too fast and you can actually brake deep and use some controlled throttle to help steer the vehicle around the corner. I used to race karts in Brasil and it was a nice trick to learn. It is funny how I can use it in my R/Cs as well.
