lutach
lutach's Avatar
11.13.2007, 05:06 PM
The motor is a high speed motor used in automation machines. It is rated at 15K rpms, has 8 poles, 57MM diameter, 70MM length, the shaft is 8MM in diameter and 30MM in length. I thought about rewinding it, but I have to get some time for myself to do that. It has a ton of torque and it is rated for 48 volts. I did hook it up to my Spin 75 with 36 volts and it said in the spin box that the motor's rpm was 25K rpm.
