Delboy
11.14.2007, 07:07 AM
Originally Posted by JPP View Post
Incidentally, one other thing I noticed is that to get mine to recognize full throttle, full brake, and neutral, I have to set the throttle subtrim to somewhere between 15 and 25 (where, exactly, seems to be random, depending on the time I turn it on), and the EPA on brake to 10 (out of 100). I am able to leave the throttle EPA at 100. I'm running a Nomadio React, have 4 other vehicles on the same radio and have never had a similar problem. Is this normal?
JPP
JPP did you ever resolve the throttle mid point problem? I have a similar issue where I need the midpoint to be recognised as OFF/Idle but the MGM will not program unless i use the full throttle/brake travel. This results in the mid point being half throttle and no brakes?
