MGM 16016 RB car setup solved.
Delboy
MGM 16016 RB car setup solved. - 11.14.2007, 11:16 PM
Originally Posted by JPP View Post
Unfortunately I had to put everything RC away for the past 2 months due to my wedding/honeymoon and home renovations. Probably won't be able to break the stuff out again for another month or so, by which time Tekin should be close to rolling out their R1MT and Castle their MMM. Or I may just switch to a MM with a UBEC and fans, since I'm just using 4s.
Incidentally, what radio are you using? Is it a Nomadio product?
On this setup we are using the stock Losi radio, I run the React on my E-LST2 which has a Hydra 120 ESC.
Finally sorted the issue. The TMM16016 is a Z-Series 'RB' ESC (Race Boat) which is not actually what I ordered. Key difference is that it only has Forward (no reverse or brake) which is fine for the LST2 so it expects different end/mid points. By offsetting the Throttle on the TX I can program it as documented and it behaves fine.
I did order the USB (and may order the Black box as well) but it is out of stock here in Australia so am stuck with the 'hit and miss' TX programming at present.
Main concern is that I have the Lipo 4S setup correctly, if I read the instructions correctly I think the ESC still does a check on the number of cells connected and fails to start if there is a mismatch?
PS There is no BEC on this model which is also OK as we continue to use the RX Battery anyway as most of the ESC's we have access too do not support 4S for the BEC, this also keeps the ESC temperature down so we will continue to use the RX Battery.
