Originally posted by rc4x4nut
I forgot to mention that I stripped one of my hex screws that holds the shock bracket to the A arm. Any ideas on how I can get it out?
What type are you using? Is it a flat head or socket cap screw?
When I was taking off my G2 shock towers I stripped a flat head screw and couldnt get it out. I ended up drilling it out and was able to pry the tower off and just have to remove the screw with pliers. If its a socket cap screw you can take a dremel and make a straight notch in it so you could then use a flat head screwdriver to remove it.
Not sure how you stripped your screw but mine was from a bad set of hex drivers. I was using a small snap on set with ball ends. Those are terrbile. I now have the Integy set and love them. A good set of drivers are a must. Mike carries this set in the store too.
