Finnster
KillaHurtz
Finnster's Avatar
11.15.2007, 11:53 AM
Tell me something, at the first time that we use the controler, how the controler will know the number of li-po cells connect to him????
They need power to turn on, and we don't have the choice to plug any batt to the controler to fire up and can go into the programation to setup the parameters...
So at the first time you use the controler, if he don't recognise the number of cell and fails to start, how can we program it????
The controller defaults to Nimh mode, so there is no voltage cutoff.
Are we sure that the controller won't even turn on if there is low voltage, or just not arm? If you messed up the cell count, ie put 6 instead of 4, don't have a 6cell lipo, it doesn't seem right that this would just brick the esc until you could get a HV pack. I could see it let you do the programming, but not arm, but haven't tried it so don't know for sure.
