rchippie
rchippie's Avatar
11.15.2007, 01:08 PM
i just talked with brian g & he suggested not to use the mm motor but to use a feigo s motor. He said a 7s with a 15t pinion would be good for around 35 with the kit tires. He also said if i wanted to use truck tires that a 8s with a 14t pinion would be good. He also said these motors would not get as hot as the mm motors because they have a little more torque. So im probably gonig to get a 7s motor. what does everyone think ?.
REAL MEN RUN BRUSHLESS
