FastEddy
11.16.2007, 12:53 PM
Originally Posted by squeeforever View Post
Keep in mind you retain the rear skid, which you don't have in the pictures.
Are you talking about the 4 stand offs?
2 short and 2 long that go from the bottom plate to the bulks?
The photos were taken many days ago when I first discovered the issues. I hand fit most parts, look, look again then look before I do anything.
I have had the spacers on and off 20-30 times now as well as all the other parts on the ass end in the last 4 days. Something isnt right and I dont know what it is.
I have bent the rear plate to what I believe is the proper position. It did HELP get the hole on the bottom closer to where they should be but they are not as precise as the rest of the kit so far. The drive shaft also jams and the top plates are under huge pressure with a bow in them once screwed down.
Thanks for the keen eye on the spacers but there is something else going on here.
