Dafni
Dafni's Avatar
08.13.2005, 01:29 PM
I don't mind at all. But I can't really help you, they are from a local electronic supplier. They are standard cpu fans. Don't remember the brand, though. Papst makes good ones, and I also use Traco fans, but they may be european manufacturers.
On the ESC I have 25mm 12V fans, and on the motor there are 40mm 5V units.
Check some online electronic stuff sellers. Also, Mike can get you fans if you like.
