11.17.2007, 11:45 AM
Ok, heres what I think:
Use the 10T pinion you linked. It doesn't need a hole since it has a flat spot. Simply use a stock dogbone cup for the LSP
Use the LSP diff. I believe the one you linked is a 43T, despite it saying its a 50. I think it says 50 because the center diff for the LSP has a 50. Type or error on there part. 4.3:1 is all your gonna get.
