11.17.2007, 01:08 PM
I cant speak about racing requirements, though a racing spec esc/motor & a normal 'bashing' spec esc/motor system would be the easiest way around that.
As for what I would like to see improved with the Hv systems:
*Higher voltage esc, 6s lipo/18cells if plenty
* Greater range motor KVs
* Stronger motors- larger magnet basically like the Feigaos (but better quality/efficiency)
* Better amp handling- the HvMaxx is rated at 400amps?, but it struggles with the 4.5 motor, so better Fets are in order- I think griffinRU would be the best person to comment about that really.
* Plugs on either end of the sensorwire harness- makes life easier when working on the truck.
Not a massive wish list, and fairly basic requests I reckon- so long as its more torquey, just as reliable and handles high amp draw well/better, I would be extremely happy.
