Originally Posted by mabu
I know - i already own one of these .. i am waiting for my revo roller
I am gonna build it with a Feigao 8XL running on 4s Lipo and a hexTronik 120Amp controller.
My last problem -at the moment- is about wiring esc and the servo used for mechanical brakes
Ok - I didn't understand your original question. There are two ways to do it. The easiest is to plug a
y connector onto the throttle port of the receiver. Plug the ESC into one ind of the y and the throttle/brake servo into the other. Be sure to disable reverse and braking on the controller. The other way will depend on your radio's capability. Some have the functionality for mixing channels. You can plug the throttle/brake servo into the third channel and use the radio programming to mix with the throttle channel and have them work together. You'll have to check you radio's manual to see if it has this feature.
