11.18.2007, 07:20 PM
Very nice Artur! (you do make it look easy having done a little modding myself now) I see you are using the 3rd generation MM boards, any problems running 6S? I seem to remember some guys having problems going above 4S, someone said they thought it was voltage protection for the new fet's...
Also on the new fet's do you have a link to the fet spec's? I've seen the part number but I can't seem to find the specific fet.
I know with the lower fet count there appearse to be "open" spots for fet's, any chance one could add the extra 8 fet's to each board and esentially be tripling the capacity?
Lastly do you think it would work to do the extended buss/dual heatsink setup like I did with mine while using doubled up power boards? (mine is working GREAT and actually feels colder than ambient after a good hard run- of course I'm running a very light load setup with the XXXT/5700KV 2S lipo)
P.S. I found carefully using a wire gauge drill bit the same size as the 22awg buss wires to "clean out" the pcb holes made assembly much easier.
Will post pic's of my completed mod as soon as I find out what you guys are using to post your HUGE pic's (wink,wink, what service /how do you do that???)
