sikeston34m
sikeston34m's Avatar
11.19.2007, 11:46 AM
well, i found a problem, id like to run this with a neu motor, but the max current for the neu i want to run is 110a, while the burst current is only 110a on this esc. is that a problem? can you give me the best motor choices thatll work with this esc no problems? thanks!
How many volts do you plan on feeding the neu?
Correct me if I'm wrong, but I believe the 110 amp rating is at 12 Series Lipo.
With heat buildup, it takes so many watts of power to build that heat. So would 110 amps at (12S) 43 volts loaded be the same as 180 amps on 6 Series Lipo?
