johnrobholmes
johnrobholmes's Avatar
11.19.2007, 12:52 PM
Yeah, the ring bearing is a press fit into both the can and the faceplate. It takes a hammer to get the motor apart once it is together. You have a bearing press? Also, the rear of the can is just pressed onto the backside fan plate in some cases, make sure to check that and seep some locktight in.
